lalla
Fisher Convert
Hello, fellow Fisher lovers.
I've just replaced my beloved 500-C of several years past with a newly restored example and am now looking for some advice. I have previously driven my Crites updated Klipsch Cornwall I's (8 Ohm, 101db) off the 8 Ohm tap of a partially restored 500-C. I would now like to drive these same Cornwalls, along with a pair of Klipsch KG-4's (6 Ohm, 95db), with a restored and slightly updated 500-C. Is this safe? If so, should I run these off of the 4 Ohm or 8 Ohm tap?
All electrolytics in the power supply have been replaced, as has been the rectifier bridge. In addition, 10 Ohm resistors have been added to cathodes at each output tube. Coupling caps have been upgraded, as have power stage main resistors (1.2kOhm, 470 Ohm).
Thanks all!!
Thanks all!!
