Thatch_Ear
Addicted Member
I bought an old B&K 500 Dynajet tester for keeping records on the tubes in the Tube Box. Yes it is going to happen and hopefully MikE will mail me the tubes colected so far. As of right now to get this tester working I have replaced the elecrolytics, the diodes and need to do so for the tubes............I need in exellent working condition a 4 pronged tube diode to replace the mercury vapor 83 and a 6AT6. Good ones. Soon as possible.
I am getting close to having the caddy restoration finished.
I also have a Seco that would be nice to get a schematic on. It is a model 107. If the squat magic eye tube is OK then I am fine sine the only othrt tube is a 12AU7. It need a major cleaning and removing of oxidation but I have silicone to replace the selenium diodes and the rest of it looks like it has indusrial resisters and such. I can tell that someone has replaced the original electrolytic and I am not sure of the value.
Let me know if you can help. Having funtioning testers that can at least do the basics are importany enough that the Tube Box (es) won't work without them.
Cable is acting squirrelly from storms so I don't know when I will be back on line again. Dig through those tubes for a 4 prong rectifier and a 6AT6. There are subs for this tube but staying original would be best for this antique piece of test gear.
Thanks, and this collection is yours! Let's make it work. And in case you are wondering nobody gets their tubes back unless they have an interest in checking out that part of the collection..................................................
David Thatcher
David Thatcher
