new from klipsch are reasonable $$.
KD15
I'm pretty sure that well has run dry Dingman.
You might be able to get by with the cloth/aleenes glue for a while. I don't know about getting new surrounds, but I know simply speakers has recone kits for the KD15 passives. That's a tough spot for a lasting repair.
You are correct, I'm sure - It's been over a decade since I had replaced a set, in Ch2's.
Quick google looks like the KD15 might be available again, as it's what's used in the Forte3's. Klipsch will have to make it available to support the product. Someone needs to call and see, I have another friend with Ch2's in need of a pair.
Hey @Bub what did you end up doing? I called Klipsch the other day and they want 149.99 each for these passive radiators. That’s a bit much.
@Speedbump71 , do you still have yours after doing the recone? Did you have any problems getting the weight in the right spot when transferring from the old?
thanks in advance!
