Hi all. I have a Sansui 3000a that has the bad output issues that they issued a service bulletin modifivation for. My unit never had the mod done to it. I have a bad left channel and I think I tracked that down to a bad resistor and a coupe of transistors.
I have the service bulletin and that calls for replacing the sm 150 diodes with s-1.5-02. Anyone know what I can use for these? I couldn't tell if those numbers are values for volts, amps or etc. Need help.
I was trying to decide if I should try to get it up and running then do the cap mod, or just do the whole shebang before attempting to power it up again. I think I'm going to do a little more poking around and measuring, but I think I got my head wrapped around what needs to be done. I've including the schematics of the original and the service bulletin. Any advice on what to use for the diode replacements?
Thanks for any input.
