I think the Orion price is OTL. I have a Five Thirty, which is similar to the Five Twenty, except it has AM and FM (The Five Twenty is FM only). I bought mine, in perfect shape, with wood case and owner's manual for $33. Others routinely go for less than $40 for working models, so $25 for a dead unit is still a bit much as far as I am concerned.
A quick check. If you have a digital voltmeter, make sure the unit is powered off, set the speakers switch to spkr1, and read the resistance across the speaker outlputs. If it reads 0 ohms be sure to reverse the leads to be 100% sure), one of the output transistors is shorted. This test is not absolute as certain amp designs will not show a short at the speaker leads even with shorted transistors.
The caps over the transistors are there to protect the transistors from being shorted to a nearly metal object. Unless you have experiance, do not remove the transistors. There are insulators and heat conductive paste that need to be installed properly. Serious damage can occur if the transistors are not mounted correctly.
I do not have a service manual, or I could help a bit more.
If the unit is in perfect shape, with wood case, offer no more than $15, IMHO. It will cost at least $30 for a service manual (according to online vendors), plus the cost to service. If you decide to pass, I would be interested in it, if you are willing to ship to me (all costs covered, plus a donation to AK).
Regards,
Joe
