elnaldo
Lunatic Member
Hello. Using the trimpot, the minimum is over the service manual specs. Should I simply "cheat" the circuit, and add more resistance in series with the trimpot? The manual calls for 40mV across 5.4 ohm (2 x 2.7 ohm emitter resistors), and I'm getting around 50-60 with the trimpot all the way to one side.
All the transistors are originals, all the soldering was reflowed (it was 600mV before the resoldering)
