Hayseed Hamfest multi-cap cans - your experience?
Discussion in 'Tube Audio' started by BmWr75, Jul 28, 2012.
  1. BmWr75
    BmWr75 Addicted Member
    5,512
    Northeast MS
    Any one here ever ordered multi-cap cans from Hayseed Hamfest?
    I ordered five for a Scott 299A. Clearly described the required uF/V, common pos./neg. and max. dimensions for each can in my order.
    Two came in too tall to fit in the cabinet and were returned for refund, no questions asked. Two came with common negative when common positive is needed. Just discovered this today, so let the seller know a few minutes ago.
    I expect another no hassle return will be forthcoming. It is aggravating though that only one of the five cans was correct and this restore is delayed even further.
  2. Hecubus
    Hecubus Active Member
    195
    Northern VA
    I've ordered two cans from them. Both were exactly what I wanted. Both work as they should.
  3. kpaxfaq
    kpaxfaq Tube Rectified
    2,648
    Erie, Pennsylvania
    Nothing but good experiences for me and many others, I'd chalk it up to a fluke.
  4. BmWr75
    5,512
    Northeast MS
    Tom at Hayseed Hamfest is great to deal with......I'd imagine this is just a fluke. We all have bad days.
  5. dsndblm
    dsndblm Well-Known Member
    950
    Central Arizona
    I used Toms caps in my 500C and 400. Perfect fit, good esr, great price. Nice people to talk with on the phone.
  6. jjblue84
    jjblue84 Active Member
    334
    Skaggs Island
    I use them, they are great. Always had good service. This last cap order, got messed up a bit...He got the caps put together pretty fast. Got free shipping on everything. Things happen every now and then. I was no hurry with the restore. Still great caps!
  7. Vinylcafe
    Vinylcafe Linvin' the Dream
    970
    Vancouver, Canada
    Very good. Used them for my 500-C.
    Great product, communication, etc.
  8. BmWr75
    5,512
    Northeast MS
    The correct common positive cap cans came this week from Hayseed Hamfest. Tom, as always, was very pleasant to deal with on this problem.
    Hope to finish up the Scott 299A type 2 restore this weekend.
  9. BuzzK
    BuzzK AK Member Subscriber
    1,741
    I'm finishing a 299A up as well.
    I chose to do all of the cans myself. I use a large tube cutter and cut the cans just above the big ridge line. I pull out the guts, etc. If they are held in by tar, I put the closed end on an electric stove or hot plate for a bit until the tar softens.
    I've discovered that you can use bottoms from other cap cans as well. I use JB Weld to glue all together and a wooden vise to hold it tight. I wipe off any excess epoxy with alcohol and the seam looks quite good.
    On some cans I'll laser print a label with the values, can polarity, etc.
  10. Sam Cogley
    31,456
    SW Missouri
    It's easier to pry up the crimped bottom edge and pull the guts out.
  11. Ohighway
    Ohighway Wannabe Minimalist Subscriber
    I provided Tom with some dimensions for a taller than stock cap that would just fit a Dynaco ST-70 with cage in place. Does anyone know if he ever started making/selling those ?
