8xlaxx
Have you ever seen a spleen that large?
Nice seeing many threads and posts about these W5M amplifiers on AK. Truly a wealth of knowledge here and of course, I'm kinda late to the game on these lil' gems.
I recently acquired two W5M amplifiers with matching WA-P2 preamps. Both W5Ms have their original KT-66 tubes and Mullards that all tested good/strong.
W5M #1: Was sitting in a dry garage for 40+ years. Has a 16309 OPT that ohm'd out at 631ohms on the output tubes of pin 3. I removed the 5R4 and connected a variac and tested the 54-32 Stancor PT and it showed no filament DC voltages on output tube pins 2 & 7 (both). Looks like a dead PT! Fuse was good. I measured 116VAC across the fuse and surgistor and to the front of the skirt socket pins 6,7,8. I had to connect one of the WA-P2s to use the On/Off switch to get these measurements. Got tone/continuity when touching pins 2 & 7 on both output sockets (powered off), again looks to be a dead PT.
W5M #2: Was purchased to get the mono-block project going even though not a matched pair. It has a 16458 OPT that ohm'd out at 481ohms on the output tubes of pin 3. That's all the testing I've done so far on this amp.
I'm wondering what might be a good decision on replacing the PT on W5M #1? or should I bag the whole idea of mono-blocks and sell amps, pre-amps for parts? I've got some sentimental attachments W5M #1 as it was my pop's amp, he was the original builder, etc. Be nice to honor his memory but I'm sure he'd be OK with me parting with it if it becomes a money pit. I could recoup the money invested so far in W5M #2, in selling off the KT-66 and Mullard valves in both amps.
Just wondering what others in this situation have considered doing and what the outcomes were? Resources on a a 'correct spec-d' PT would be interesting but then again, the Peerless 16309 OPT might get flaky one day and then I'm back to square one.
I want to thank @dcgillespie for helping me with the testing points for W5M #1. Again, many thanks!
