m1k35r
New Member
Hi all... I have a strange problem with a McIntosh 250 solid state amp. No sound on one channel, very low distorted sound on the other. If I remove the input to each autoformer, the sine wave at the output of the power transistors looks symmetrical and great. Hook up the transformer, and it stops working. Any idea what the measurement (ohms) should be from the input to the 4,8,16 output taps? They all measure very low, about 1.4 ohms each on both transformers. Also, with the output transformers hooded up, the sine wave at the driver transistor (TO-66) on the driver board shows the top half of the waveform to be good, the bottom half is almost a flattened triangle wave. Although I believe it to be rare, I think the autoformers are bad. Any ideas would be greatly appreciated.
