Help me decide: Transitors
Discussion in 'Solid State' started by drumbum, Dec 29, 2017.
  1. drumbum
    drumbum Super Member
    1,340
    I have a couple QSC series three 3800, one has a bad channel; a few bad outputs, so far.
    The amps have Toshiba 2SD424/2SB554. Plan to replace bad in pairs with MJ21193g/94g, don't want to couple an old Toshiba with a new ON semi.
    Three pairs of the ten (20 total per side), hmmmm.....
    Should I replace the entire channel with the On Semi combo and sell the good Toshiba's to recoup cost of new outputs? Would this help someone or should I stash 'em for future needs?
    Should I use the 95/96 instead?
    What would you do? Yes, you...there in the back.
    Thanks for any input on my outputs.
  2. drumbum
    1,340
    Seriously, ...I can't edit the title?
  3. drumbum
    1,340
    Six of ten bad 2sb554's.:thumbsdown: 424's test good.
  4. awillia6
    awillia6 Super Member
    1,385
    Some things you just have to get right the first time. Trick is knowing which ones they are beforehand.
    DRecovery likes this.
  5. redk9258
    redk9258 AK Subscriber Subscriber
    1,625
    Illinois, close to St. Louis.
    True of so many things in life!
    I think you have to be a paid subscriber to edit a title.
    petehall347 likes this.
  6. awillia6
    1,385
    I got another one! Money can solve problems that nothing else will.
  7. drumbum
    1,340
    Harry, all output transistors were pulled and checked with dmm set to diode test.
    You wouldn't advise to change all the 2sd424's. Have you coupled new mj21194g's with old 2sd424's?
    Also Harry, is English your first language?
  8. avionic
    45,611
    Fort Dodge, Iowa
    No.... If your going to replace outputs use complementary pairs.
    UncleBingo likes this.
  9. drumbum
    1,340
    I have 5 each in hand. Waiting for the other ten from mouser (back ordered).
  10. elnaldo
    elnaldo Addicted Member
    7,442
    Buenos Aires GMT-3
    You can use a power amp with less output transistors if you don't need all that power. I usually install just one pair until the amp performs OK, I test it for some days before installing (and risking) an expensive batch of transistors.
    On other "bench amp" I've got for free, I never installed all the outputs, it runs with just 4 transistors (2 each channel), since I never play it loud.
    To match transistors without test circuits or test equipment, you can install them in circuit, connect a dummy load to the output, and play some 100 to 1000Hz sinewave, at mid volume, not stressing the amp, and measure AC (audio is AC) across the emitter resistors, to check if the voltages are balanced. One transistor conducting much more that the rest will show a higher voltage drop. Choose the parts with similar performance.
    I suggest to use a low freq (100-200-500Hz) since standard DMMs are more accurate measuring low freq AC.
    I'd do this test using a Dim Bult Tester just in case something goes wrong.
    dlucy likes this.
  11. drumbum
    1,340
    Thanks for that elnaldo.
    I'll try to digest that and make a plan.
  12. elnaldo
    7,442
    Buenos Aires GMT-3
    Basically, "matched transistors" share the load approx the same between them. This way you check that, an actual load in the amplifier, being shared by the transistors in parallel.
    Anyway nowadays manufacturing tolerantes are tight, so I think you'll be fine just buying new transistors from the same source. I'm sure they will perform very similar out of the box.
  13. drumbum
    1,340
    The key is going to be finding why one 554 shorted bad enough to burn the board and lift the trace to it, and take out 5 other 554's.
    So far I've found one resistor leg lifted, like not soldered properly in factory, one main filter cap (12 2200uf 100v matsushitas) loose, unsoldered. Bridge rectifiers seem fine as do the rest of the resistors (aside from the 15ohm 1w I just found). Driver transistors seem fine but will double check.
    Once I have the old thermal paste cleaned up and all outputs installed, I plan to fire up channel with DBT.
    What tests can be done with a DMM on capacitors aside from a dead short?
  14. drumbum
    1,340
    Remaining T0-3's came in thurs. Got them installed with about .5" of solder left:rolleyes:.
    DBT fail:mad:. Tested everything...but the one of two bridge rectifiers. Sho nuff bad.
    Replaced and all good:banana:
    Have some re-assembly with thermal paste to do yet and adj. bias.
    QSC series three 3800 up and running. Now on to cosmetic resto of the other working 3800;)
    375w@8ohm 20-20 600w@4ohm 20-20 .1%thd .015%@1k thd
    75 pounds of fanless dual mono construction.:beerchug:
    elnaldo likes this.
  15. Oldsansui441
    1,831
    Victoria, Australia
    Good to hear you have her up and running :).
  16. drumbum
    1,340
    Now to figure what the hell to do with...
  17. drumbum
    1,340
    Maybe I could rent it out to help pay for an S.:rolleyes:
  18. classic carl
    classic carl Without Music, Life Would B FLAT. Subscriber
    6,214
    North Coast of Pa.
    I believe only Subscribers can edit their titles. Click on the report button at the bottom of your post and ask a mod to change it for you.
