deadbone
New Member
A couple of months ago I inherited an old Sony receiver (STR-AV920) and CD player (CDP-C705) from one of my father's coworkers. They're not the greatest gear but for the price of free I'm pretty satisfied with them.
Soon thereafter I noticed there was a channel imbalance with the receiver; the left channel was significantly louder and clearer in the high frequencies than the right. I swapped the speakers around--nope, not them--and noticed the imbalance with headphones too, so after a bit of online research I assumed it was probably the result of aging capacitors or something and decided to even it out with the balance control.
Lately the problem has been more noticeable, requiring the balance to be set around 2 or 3 o'clock and this with a clear loss of clarity. I opened up the CD player tonight to adjust to tension of the chucking arm and decided to take a look inside the receiver as well.
So one of the two largest caps on the board is slightly bowed out on top, and there is a pool of white paste around the base of both of those caps (see pictures). I don't know much about electronics but I assume these are the capacitors for the output stage, one for each channel? At first glance I thought the white substance was thermal compound (do caps produce heat?) or something but at second thought and smell I wonder if the bulging capacitor is leaking.
If that's the case, should replacing those caps be relatively straightforward, and is that likely to fix the channel imbalance? I found capacitors of the same spec (?) on digi-key for less than $10 for a pair (part no. P7492-ND). Would these be a suitable replacement or am I going to need some kind of special audio-grade caps? Obviously this is not a great receiver. If I can fix it cheaply I'm all for it, but putting too much into it (say more than $25ish) doesn't make sense.
Please forgive any ignorance in this post and feel free to correct it. Thanks!
