I have finally found the time too work on my friends sansui 9090db. Its been sitting for a couple of years and was stuck in the protection mode with a flashing red indicator. It was either I can try and fix it or it would sit on the basement self, he doesnt want to spend any money on the old sansui. Thanks to Lapete for the info on the R33 and R34 resistors on the power supply board. He said they could be open or out of tolerance. Now believe me I know hardly anything about fixing stereo equipment or electronics, about the only thing I can do is deox the pots and switches that is it, I can solder perty good at least get the job done.As with working with a multimeter not good at all dont understand most of the measurements. Anyway after reading the meters book I figured out how to check OHMS. I found that the R33 resistor measured 307 OHMS way to high because the resistor should be 180 OHMS, the R34 resistor measured nothing it was open.So I put in some new resistors 1/2 watt 180 Ohm, I think the factory ones are 1/4 watt 180 Ohm, but I read somewear on the forum to up them to the 1/2 watt ones so I did.Man this was the first time soldering a circut board I was very carefull and it turned out very nice I was scared to death of burning up the board but it was no problem.
So now time to see if the 9090db would go up in smoke or work. Crossed my fingers and hit the power button and the red light blinked for about 2 seconds and turned green wow!!!!! I got my cd player and hooked it up to the sansui and was using a set of junk speakers (old panasonic ones), and I have music couldnt beleive it the old sansui works. The only thing that doesnt seem to be perfect is the balance, the left channel is slightly more loud than the right, not buy much thow,if I take the balance control and move it about a quater of an inch to the right side it evens out, also the right power meter reads lower than the left when playing music. So I switched the speakers on the back of the receiver, still the left side was a shade louder than the right so I know the problem is in the amp and not the speakers. Dang, deoxed the volume and balance control again no luck. I tried the tape input with my cd player and aslo the AUX input still the same, even switched the CD plyers right and left cables from left to right and right to left nothing but the same problem.Every control and switch I cleaned the best I could even the dolby switch which is a bite to get too. Any ideas beside using the balance control to even things out?
I know also that there is something to do with DC offset and bias that can be checked but I dont know how to do it could this be the problem maby?How hard is it to bias and check the DC offset any help would be great.
