home made contact cleaner
Discussion in 'Solid State' started by hifibill, Oct 14, 2008.
Thread Status:
Not open for further replies.
  1. hifibill
    hifibill New Member
    37
    ...any good homemade switch contact cleaners? found an old panasonic table radio (with phono input). the selector switch doesnt make solid contact -cuts out-...any ideas/suggestions....
  2. Sansui Louie
    Sansui Louie Curmudgeon
    4,836
  3. ManFromPorlock
    ManFromPorlock Super Member
    2,263
    The first contact cleaner I was ever introduced to was straight denatured alcohol, which worked well on carbon film pots. However, you can get a big can of CRC Contact Cleaner at any Home Depot (or Lowe's, I guess) for six bucks or so and in terms of peace of mind (denatured alcohol is unfriendly to things like solder masks) it's worth it. CRC isn't as good for tough jobs as DeOxit but it's 'good enough' in a lot of cases and a lot cheaper and easier to get.
  4. similost
    similost Rockin and Rollin....
    37,894
    West By God Virginnie
    For a power switch, I would either find a new one, or disassemble the old one if possible, and more than likely end up filing down the contacts. A switch that is old and well used is a lot different than a dirty pot.. the contacts actually arc and burn, so you need to dress them if at all possible.
  5. Grumpy
    Grumpy Krusty old SOB! Yes, I own Audiokarma Staff Member Admin Sponsor Subscriber
    26,124
    Texas
    The mixing of dangerous chemicals will not be discussed on Audiokarma. Either ask this question elsewhere or use one of the many ready made available products.
    Grumpy
Thread Status:
