I’d imagine they take a larger piece of the stylus material, machine the end and then grind/cut off the “stem”.I'd still like to see how the styli are machined! And how they're held while so doing.
And we've had microgroove styli since the 1950s, so it's not new technology.
I believe all styli begin as spherical; the exotic shapes are sculptured into it, adding more complexity and cost. Certainly the elliptical and Shibata are shaped from spherical tips.And my guess is that it may be simpler to grind a Shibata contour than a spherical or truly elliptical point.
Really would like to know!
1. A reproducing stylus for a record having a sound groove, said stylus formed by removing to a predetermined depth front and back portions of its contact area with the sound groove to obtain an edge portion of said predetermined depth having an orientation perpendicular to the direction of record travel where the effective radius of curvature of the stylus at the edge portion is substantially reduced with respect to that at the contact area prior to the removal of the said front and back portions.
Ouch! Those sharp bottom corners look like they can do serious damage to a record. Is that his so-called "twin tip"?
Boy, that sure is a lot of work!
(a) Top-quality octahedral diamond is used as the raw material.
(b) Diamond powder is used to polish along the crystal axis.
In order to process the tip, the crystal is inserted into a metal rod and carefully polished.
(c) The point can be formed into desired shape, such as round or ellipse.
Afterwards, the crystal is removed from the metal rod and the opposite end is cut down.
The 'bi-radials' are a very different cut compared to that patent, as far as patents go. The spherical tip is not truncated as it appears in Grado's patent.drawing of the first "eliptical diamond stylus" he did in fact call that a twin-tip. Bi-radial, for all those who didn't want to infringe on a patent name
