Robert2017
I don't understand exacty how the power supply main caps and the preamp power supply main caps are affecting the amp sound signature ?
I mean different caps have a different sound as shown in this videos post bellow. So it worths spending money on the best sounding caps for the power supply ?
Some will say that power supply caps don't affect the sound signature because "power supply filter caps work to supply smooth -- and silent -- DC" or that "power supply filter caps aren't in the signal path. They're part of a circuit to generate smooth DC to power the rest of the amplifier circuitry and smooth DC doesn't have a sound, because smooth DC doesn't vary the position of the speaker cone."
I'm sure that the power supply caps are affecting the sound signature because I made a lot of mods by changing different caps.
I don't want to start a debate about blind tests vs normal tests or caps have no sound vs caps give a sound signature.
So how the main power supply caps and the preamp power supply caps are affecting the sound signature ?. What is the process ?.
For example here is an article :
http://sw1xad.co.uk/black-gate-vs-kaisei-capacitors-review/
All capacitors were used in the HV power supply section of the 6N6P/6N30P tube output stage.
All judgements expressed are a result based on a head to head comparison two identical DAC circuits before and after the burn in period of many hundred hours.
BG pros:
BG cons:
KAISEI pros:
KAISEI cons:
The difference is obvious with the cheapest earphones ... not speaking about hi-end speakers or acoustical special rooms ...
started another thread to become an informative one for those seeking explanations.
I think a technical side explanation is worthless without artistic terms like the "sonic signature" of PSU main capacitors.
After all is about music expression.
So in my opinion the explanation needs to be more on the musical signature side but combined with the technical side.
BG pros:
- Pitch dark background
- Brutal dynamics and radiant energy across the whole frequency spectrum
- Addictive mid- bass quality and quantity
BG cons:
- BG caps are not perfect; they lack clarity in the top midrange end (relative to KAISEI)
- Many hundreds of hours run in time
- Availability and price
KAISEI pros:
- Superb clarity /Transparency/Resolution but retaining warm sound
- Complete lack of haze relative to BG
- Silky smoothness in the midrange a la paper in oil foil (PIO) type caps
- Fluidity in dynamics comparable to solid film capacitors
- Frequency extension associated with non polar version of BG
- Sound nice straight out the box with much less run in time needed
KAISEI cons:
- Not the last word in dynamics and mid bass weight relative to BG WKZ (one of the best sounding power supply caps known to me)
- Similar price relative to the original Black Gate retail price
