I picked up pair of 9844a a few weeks ago and haven't had much time to play until the holidays. I gave them a quick visual the evening that I brought them home and they looked good and measured generally as expected given that the crossovers were modified. Getting the cabinets into the car and into the house was no problem at all, but once I grabbed one of my boys to help me get them down the basement, that is when the weight of these things became immediately apparent.
Once they were successfully in the basement I had to figure out where to put them. Since they were the new toys in the basement I put them on top of my JElabs/JRob work in progress so I could at least wheel them around while I further checked them out. I pulled the covers off of the horn drivers and they are at least original Altec parts. It also looks as though the woofers were replaced at some point since they look like later models, have no dates codes or they are dated differently, and by the fact that there are extra screw holes in the baffle, but I could be wrong...
I also pulled the crossovers to see what was going on and the pots were replaced with a 20R resistors, which I left in for now. I fired them up on a few different amps including a 300b, DG SEP magnavox, and a 60 watt Lm3886 chipamp and I am pretty happy with the way they sound with each amp. Next up is a quick rewire to see what I can do with them bi-amped using the minidsp that I have setup for my A7s. So far, I prefer the upper end of the 32b with the 414z combo but they also play much higher due to the phrams installed, but the bass of the 9844a is very nice and articulate and only a little glare from the 811s. Now I really need to get my act together and get at least one of my Altec projects to the point where it is at least done for a while as I'm running out of space to move them around! Not complaining though...
Happy holidays!!
KC
Happy holidays!!
KC
