Hi all, It will take someone with better math skills than I have to answer and explain this question. Does increasing or decreasing the size of an idler affect the platter speed? John
No. You are thinking of axle ratios, the issue at play here is surface speed. The only important ratios in this instance are motor spindle diameter to rim circumference.
Assuming the motor/idler wheel speed is constant, yes any increase or decrease in idler diameter will affect platter speed. Larger idler diameter = faster platter speed Smaller idler diameter = slower platter speed
I don't think so. The smaller the idler the faster it will turn but the surface to surface ratio at the platter would be the same.
No. The distance the motor pulley covers on the idler will transfer exactly to the inside of the platter no matter the size of the idler. 10mm of movement between motor and idler = 10mm of movement between the idler and platter.
Incorrect. The diameter of the idler wheel will have absolutely no effect on the final drive speed. The only way to change the final drive speed (short of changing the motor speed) is to change the diameter of the driving member (motor pulley) or the driven member (platter itself). The idler pulley simply transfers the energy from the driving to the driven.
The answer is no, changing the idler diameter will not effect the rotational velocity of the platter. http://en.wikipedia.org/wiki/Idler-wheel However, alterations to either the platter or motor spindle diameter would effect the platter velocity. *Edit* Wow, two posts popped up while I was typing.
I proved this when I was about 5-6 years old when my VM Playtime record player seemed to be playing too fast. So, I reasoned that if I filed the idler down it would drive the platter (plate) slower. Didn't make a cotton pickin' bit of difference. Doug
I stand corrected, sorry for any confusion. In my mind I was thinking about the drive wheel which turns the platter versus the idler (intermediate between motor and drive wheel).
I once had to carefully file down the motor shaft of a BSR aka Best (for) Scratching Records to slow it down. 33 and 45 ran way too fast.
There are some idlers which are actually "double decker" wheels where a larger wheel is driven by the motor pulley and a smaller wheel drives the platter. Reducing the size of either of those wheels WILL reduce the speed of the platter. EDIT: Oops. I have to correct this. If the larger wheel is reduced (the one driven by the motor pulley) the platter speed will increase. If the wheel driving the platter is reduced, platter speed will decrease. Doug
My Presto.T18-turned-into-a-Lenco project will speed up or slow down depending on which Lenco wheel I have installed. The only difference is an old worn wheel vs. a new Mirko wheel. This is confirmed by a KAB Speed Strobe mat and light. It requires a speed readjustment if I change wheels (easily done with my DC motor and its controller board). The drive capstan on this deck is one fixed size, not stepped or tapered, and speed changes occur by slow and speeding the motor to appropriate drive speeds. With that said, there is an obvious speed difference in just changing the tire size; the Mirko wheel is cut to the diameter of a new Lenco wheel.
I've experienced speed changes with old vs. new idlers before too, but it wasn't because of the diameter. The new wheel gripped properly and corrected the speed inconsistency whereas the old wheel caused the speed to go off. Putting the old wheel in a drill press and gently scratching off a little of the old surface with crocus cloth put it right again.
The aluminum Lenco wheels stay soft, even after 40 years; fine rubber. By "worn" I'm merely suggesting that the knife edge of the wheel had worn down to a rounded knife edge; minor variance, but noticeable speed change.
How is it not debatable? - I experienced it extensively in the driveline renovation and redesign, dry-fitting, and final execution of my renovated deck. I'm not extending hearsay, rather, I'm extending firsthand facts of what happened over a years retooling of an idler deck.
1 = 1, INPUT SPEED = OUTPUT SPEED, Rotational velocity both receives and sends at the same speed; conservation of energy, energy can be neither created nor destroyed without the expenditure or expulsion of force. I've understood since I was a 5 year old kid playing 78s that idlers were speed neutral, they neither add nor subract rotational velocity. The rim would have to shrink or expand during a half-turn, with the change in mass being created from or sent to a fifth dimension. It can't happen. The angle of the two contact points remains fixed. It can't change, it is hard-coded into the construction of the wheel. The angle of bisection would have to change during rotation for there to be a speed differential. P.S. I have several Lencos, an idler CAN affect speed if the ANGLE between motor pulley and platter changes. If the receiving point remains at the same place on the motor pulley, but the drive point is moved INWARD on the platter, then the platters's driven radius becomes smaller and the platter turns faster. That's not the SIZE of the idler, but how the lever holding the idler is bent. On a Lenco the idler describes an arc UNDER the platter, if the EDGE of the platter is driven then even a skewed idler does not affect speed (except via edge crawl)
The Lencos are unusual in that they have a cone shaped pulley for that infinitely variable speed, and wear in the idler changes where it contacts the pulley, so that it does change speed, but because the pulley contact diameter has changed. I suppose this might also happen with more normal idler that have speed adjustments. But all that's happening is that the idler is transmitting a higher linear velocity (or do I mean angular -- it's late in the day and my mind isn't as sort of sharp as it can be).
Nat, I fit a Lenco wheel into a Presto T18, converting it from a three wheel Presto idler, to a single wheel idler, driven by a capstan without steps or tapered capstan. Its now an internal rimdrive Presto driven by a Lenco wheel, and precision DC motor w/ controller card, not a Lenco deck. This is a side view of the redesigned driveline: The driving portion of the capstan is not tapered. The only taper in the capstan was to allow the captan to run closer to the decks top plate, but its below the drive portion. From this build: http://www.audiokarma.org/forums/showthread.php?t=380100
