Single piece or linear strip gaskets will work just fine as long as there is a consistent ring of compressed material under the driver flange.
The original HF controls used in classic AR's are potentiometers, not L-pads, and may or may not be suitable for re-use. It will all depend on their condition and your evaluation. Also, many AR-2's employed oil-filled caps which very well might not require replacement. Please show pics as your project progresses.
OK....no resistance from me.....resistance in series and resistance in parallel. Its an L pad.
The metal baskets are very robust, but the original putty can sometimes be very tenacious, so back each screw out carefully and then begin to find a willing spot to pry up the edge of the woofer and work around the circumference until it becomes free.I'm going to practice removing the woofer on another AR2a
How are they not L pads? They put resistance in series and resistance in parallel. Its an L pad.
If it has three wires going to it, its an L pad.
It is true that an L-PAD will provide a somewhat constant impedance load to the particular section of the crossover network. It is also true that not all speaker manufacturers used L-PADs for crossover controls.
I find them to be different in many ways.Likely the same material with a different pigment.
The inert additives used to provide bulk are likely identical. Mortite is mostly butylene rubber with some calcium carbonate added, plus a little titanium dioxide for color.
Carbon black could, however, be added for color. This is what makes materials black. Titanium dioxide is white, just like in white paint.
So it may be the same material. No way to know.
What I do know is that all of the accounts of AR and KLH putty are identical to Mortite, and the discussions over at CSP all discuss butylene rope caulk as the suitable replacement.
