I have the Nelson Pass article & schematic, have been studying it. I also have an LX13 (800Hz) crossover, was considering also a N7000 for the mid/HF crossover at 7kHz, then I have external terminals for tri-amping. However, I'm not a big fan of passive crossovers, which is what led me to 2-way and electrostats, ... I have used active crossovers and been happy with the result. I have a couple of options on 3-way active crossovers, a good DSP would be even better to avoid phase distortion entirely (I hope). I will use tubes for HF and MF and SS for the LF in this case. All are very efficient so it will be perfect for tubes.
Interesting that Nelson Pass felt that it was difficult to make much of a subjective improvement on the stock JBL crossover, or any JBL crossover though.
The other option is to do it like ESS did with two jumper strips for each driver so that the crossover is cut completely out of the circuit, which I very much like. Connect all and use one amp, connect just the HF and MF together for a bi-amp setup, or separate all and tri-amp.
