Is that the one that's been on the 'Cuse or Utica Craigslist for a bit? Can't tell you how many times I almost replied to that ad (if it's the same one). Nice table.
Funny, me too.Is that the one that's been on the 'Cuse or Utica Craigslist for a bit? Can't tell you how many times I almost replied to that ad (if it's the same one
The cartridge is an XLM Mk III correct? See if you can hunt up a genuine XT-IV stylus for it. Pricey but keep looking you can get a good deal once in a while. Very nice top of the line stylus.
Yep,
You are going to have to take an ohm meter ( or inductance meter ) and measure the r ground to right + and l ground to l + resistance ( inductance ). Once you have that we can figure exactly which ADC body you have. There are many threads about ADC XLM cartridges here.
Yep,
With a resistance of 630 ohms you have the ADC XLM MkII (unimproved) cartridge. The proper and very good I would add stylus is the 114 DET. This NOS stylus is available from Gary at thevoiceofmusic.com ( no affiliation). "Get yours now while supplies last!" As a side note, the improved bodies (IE MkIII) will ohm out at 820 or so ohms. You do not want a XTIV with your body, the sound will be too bright, it is intended for the MkIII bodies. Still you will find the 114 DET in your body to be a very nice combo. It is the cartridge that really put ADC on the map.
Hope this helps.
Do the feet have a spring or anything in them? It looks like a pretty standard foot. Like in furniture?
