I have a problem, I measured idle current on both channels of the 9400, one side is sweet and adjusts perfectly, the other side is no good. I pulled the outputs (they are new MJ's) and test perfectly pretty sure this was the channel with two blown outputs when I got it. History; I rebuilt both power amps with the suggested parts and I also performed the service bulletin on both amps, rebuilt the power supply, and all boards except tuner, filter caps replaced, lamps replaced with LEDS, everything works except for the original bad amp. I cannot adjust idle current on that amp, no matter how much I turn the trimmer i'm getting 0.0 mv on every turn. There is a bias diode attached to the heatsink like some pioneers and realistics that I have rebuilt, i've tried to measure this with my Fluke DMM and I'm getting OL in diode mode . Could this be the issue with bias on this channel, the other channel which is attached to the unit is getting 980ohms in diode mode, the original bad side is getting OL. Could the oscillation from the original outputs have taken out this part? Is there a source for a new diode or is there instructions to build a new one, I'm thinking this is what is screwing the idle for this channel.
Echowars (Glenn) please lend a hand.
