bro4000
New Member
Gents, I have searched the forums and I need some expert advice. I want to do all of mods/upgrades possible to my Kenwood KR-9600 but I need your recommendations on some parts due to some of them being outdated and not currently available. I plan on keeping this receiver and don’t mind spending extra money to get a more powerful, reliable and better sounding receiver. I am trying to get most of my parts from Mouser and Digikey. BD enterprises also if needed. Thank you in advance!!
· Power switch mod - adding Zettler or Omron relay, .1uf Quencharc, .1A fb fuse, fuse holder and safety cap per Echowars and others.
· Regulator board - upgrade to 25W alum case resisters and transistor upgrade
· Upgrading the transistors in the amps. What do you recommend as the best on each specific location below?
· Tuner - upgrading the socket and opamp to AD823ANZ-ND. Adding two .22uf bypass caps to opamp supply pins between 4&8 and ground. Swapping zener diode dk4 on power supply with 1N5242B. Then removing caps at CB47 and CB51 and installing wire jumpers.
· I want to do a full recap and replace bad resistors in all of the boards but I want to do the upgrades first.
**If any of you have any more advice or suggestions for this receiver I would greatly appreciate it. I feel the KR-9600 is currently one of the best bang for the buck 160 WPC receivers right now. Thank you in advance for your help and thank you for sharing all of the info that you have on AudioKarma. Take care
- The Digikey PN 490-4217-ND for the safety cap longer available. Does anyone have another recommendation?
- Is the .1uf Quencharc the right value in this Mod?
- Mouser has a 60 ohm wirewound resistor. Should I use that instead of a 75 ohm for replacing the two original parallel 120 ohm resistors at R1,2?
- I also want to replace the (R3)82 ohm and (R4)120 ohm resisters with alum case. Would you stay with the same values?
- Also replacing the Qr1 with MJE15032G and Qr2 with MJE15033G. Are these the best transistors to use here?
- Would it be possible to use one (great quality) 22,000uf cap per side instead of two (low quality) 12,000uf ones in parallel per side? Such as a Pioneer SX-1050. I have seen a lot of nicer caps at 22,000uf.
- If this is not a good idea or can’t be done, what are the best 12-15K uf ones that I could use?
- Do I need bypass caps and/or resistors across the main filter caps? If so, what values?
- At Qe1,2 (matched) – should I use the Zetex ZT694B (noting CBE pinout) or 2SC2240BL?
- At Qe3-5 – should I use the Zetex ZT694B or 2SC2240BL?
- What is the best to use at Qe6?
- What is the best to use at Qe7?
- What is the best to use at Qe8?
- Is this the best Opamp and does this tuner mod all seem correct?
- Any mods to fix these?
