miles2go
Member
Good evening... I figured since cooler is arriving, I can put this amplifier into service, or at least that's the plan. The amp uses what looks to be an ultra-linear power amp with dual rectifiers. I will try to get a schematic up with the post. This was a kit amplifier and by all appearances, the builder did a good clean and tidy assembly. The electrolytics in the power supply were replaced just before I purchased the amp locally. The gentlemen was very honest and disclosed the bias issue as we corresponded, I ended up getting a considerable deal because of this.
Fast forward about six months to last night when I decided to take a closer look at the issue. I have a quad of Winged C EL-34's from another amp I used as test subjects and took some voltage readings after bring the amp up on the variac. It became evident once I hit around 100 VAC or so that the grids were hot. The schematic calls for 4V on the control grids and 40V on the cathodes. I took readings @ 115 VAC input and anywhere from 4.8V to 5.4V on the grids and 38V - 39V on the cathodes. There is a balancing circuit as part of the bias control which I believe may be the culprit since after balancing the pairs by way of the test socket yielded unbalanced readings directly at the grids to chassis ground. After measurements were taken, I dimmed the lights to look at the plates in darkness and noticed a glow like a line through the length of V11 and possibly a bit on V9 as well. My other concern is the screen grid measurements 5V higher than the plates, the schematic shows a 10V favor to the screens so this is obviously by design.
So my question is, what kind of precautions or modifications can be taken to avoid over dissipation? I am not opposed to cathode bias and by-passing the current bias control. I have looked at a number of Williamson type circuits and it seems that grid leak resistors are generally larger than the 150K found on this amp, also most schematics show a screen grid dropping resistor up to 1K in value. Would it make sense to add those to this design? Thoughts?
