A black cabinet version of La Scalas came up for sale at a very good price here so I grabbed em. The plan is to go through them and bring everything up to speed and then determine if they go or stay. I really dont have a place for them but I thought it would be at least fun to see what they are all about while bringing them back to life.
Previous/original owner used them with his instruments, mixer boards amps etc as a musician. The terminal connection he had on them was for patch cords, not that it matters though as I quickly just pulled that off to run cables direct to the original terminals.
The contingent is as follows:
Crossover - AA with PIO caps etc.
Woofer - K33E
Mid - K55-V with K400 horn
Tweeter - K77
All drivers work and they sound pretty good, except I think I have a little less output/sound on one of them. Seems like the mid horn is not outputting as much as the other but it is hard to tell. I guess I should disconnect the tweeters and woofers and listen that way. ?
So, hit me with things I should consider or need to do. For now I would rather stick with original stuff and then go from there. If I am getting slightly reduced sound from one speaker, my first instinct would be crossover issues. With these being PIO caps I am not sure if that would be the case though. They are really dirty so I will for sure get in there and clean them up to see if that improves a connection or something.
Can diaphragms weaken and result in reduced output in a horn? Is that something that can be tested for?
I only hooked them up to the pictured Pioneer SX5580 for now (went with the all black look) but plan on using tubes with them for sure.
Woofer - K33E
Tweeter - K77
