Lab-400 Advice Needed
jim249
Hi All; Just pulled my Lab-400 out of the closet to use it but there are a few things not right with it. First off the cue damper is sort of working. I am guessing that the piston right below the cue lever is the damper so it looks like I need to add some damper fluid to the piston and rod assembly? It is buried in there quite well so I don't want to risk taking it apart. Second item is the muting function is not working. A closer look shows the black cam lobe for the muting switch is not riding on the timing motor plastic wheel. The plastic wheel is split at the hub but still appears to work. Adjustable? The third item is does the anti skate control need any lubrication or should I just leave it alone? Thanks for any help!
