I'll check with McIntosh to see if what they have is a NOS Vactec VTL5C2 (144-159) and VTL5C9 (144-070) or if it is a substitute. Will post the results so everyone will know.
I closely inspected the 045864 boards and see that LDR 201 thru 501 are all the same part number. Schematics clearly show that they should be different but they all say: 21L682-9433 on the body of the device. I've looked at the specs for both devices and their operating characteristics are completely different. The difference could be the reason it's not working as it should.
I'm wondering if the folks at McIntosh made an error when they put these things together.
The MC-2255 had a total of three different driver boards throughout it's production run:
Driver board V1: S/N's CT1001-CT2449, V2: S/N's CT2450-CT3263, V3: S/N's CT3264 and above.
My second MC- 2255 had V1 driver boards. It used CLM6000's for the muting & powerguard LDR's.
Without an early service manual it would be difficult to confirm, but I don't believe McIntosh made an error in putting the same LDR in both location on earlier units. I believe there was a revision and they changed to using 2 different devices, most likely on the V2 driver boards. This is just an educated guess based on what I've seen -
#1 2255 - Late production model, V3 Driver Board, CLM6000 & CLM6500 for LDR's
#2 2255 - Early production model, V1 Driver Board. CLM6000 in both locations
MC-2150 - V2 Driver Boards, CLM 6000 & CLM6500's
I have a MC-2250 that I'll have to open up to confirm Driver Board version.
