I am not sure about others, but my vintage journey goes in cycles. When I started getting back into vintage audio after I retired I started with the lowly receiver. I wanted to see and touch and hear all the brands I could. I bought and sold over and over, just having a blast. Last year I decided to start buying integrated amps and receivers. For my main system I settled on an almost all Marantz; 250 amp, 1060 integrated as a pre amp, 6150 TT, Imperial 6 speakers and a Marantz tuner.
After buying amps and tuners from Kenwood, Pioneer, Fisher and Sony My interest began to fade on them. They were fun but not as fun as receivers. So I sold some of the integrateds and moved back into receivers on a smaller scale. I found some units I have never seen like the Quadraflexs 979 and a Fisher RS 2007.
But my original interest was in Realistic stuff. Probably based in nostalgia but I like things that are not the same as everything else so I started looking for Realistic receivers again.
The first one I found was steal on eBay that no one had bid on. An STA 85 from 1978. Unusual for the time with a black aluminum face, it also has a walnut veneer case and a handsome cream colored dial. I had had one before and liked it. Rated at 35 wpc it has plenty of power to run any of my speakers easily. It is good looking and great sounding. It had burned out lamps so I ordered and installed cool white LEDs. It works perfectly. I think I will use it for a while then probably sell it
I have had and still have mainly units from the 1970s, they are old enough to look cool but new enough that most SS teething problems had been sorted out. As I looked around on eBay and other sources I kept seeing these 80s Realistics that went to quartz tuning for really cheap. For months I kept ignoring them but I finally stopped to look at a few. Most of the lower powered ones (around 50 to 70 watts) were made in Singapore or Korea. Now I know there is decent stuff made there but I prefer the items made in Japan from that time frame. When I looked at the STA 2600 (100wpc) I notices that it was actually made in Japan! Ah Ha!
So just to dip my toes in the water if BPC (sorta) I bought one cheap and got it today. The dumb thing weighs a lot more than I expected and seems to be built fairly well. I does have plastic knobs but the pots turn with a quality feel. It was just a bit dusty inside and everything else works perfectly, none of the controls need cleaning either.
Right now I have it running in my dining room on FM with some small Polk TSX110s to shake it down. I have noticed that a lot of the stuff from the 80s sounded just fine, but were hard to fix if not impossible. This unit seems to be like that. It freaking sounds great and its not dead yet. This will be one I just might keep until it dies then part it out.
And also the usual question: Who knows who made these units in Japan for RS?
