How do you "smokers" maintain the temp? That IS my biggest problem with smoking.
What type of rig do you have?How do you "smokers" maintain the temp? That IS my biggest problem with smoking.
I have a Chargriller Pro. Basically a barrel cut in half with a side fire box, image is exactly like my setup. It's the wide swings it temperatures that get me. When I smoke
ribs, I check every 1/2 hr. Sometimes I think it's a "mistake", and not the norm when the temp. is right on. Yep, drives me crazy, but I've never thrown out a slab. Maybe a little dried out, but since I use a good sauce, it's ok.View attachment 915480
It's always just inside the garage, so wind has never been the issue, and the grill has never had a drop of rain on it. It does a great job on steaks, and burgers and brats,I have a somewhat windy back yard. Years ago I bought a propane smoker/grill.
It was impossible to hold a steady temp. Gave it my bother in law who used it with no issues till it literally rusted apart.
Recently picked up an electric smoker. Better insulated and holds the temp quite nicely.
Maybe your smoker need a better location if you have that problem.
I never could get easy/consistent results with foil wrapped wood (chips or chunks). Same as you - good smoke for a bit, then flamed out.I have the same thing. I don't have a lot of trouble with the temperature - more with maintaining smoke. I get good smoke for a while, then my chunks start flaming and its done. So then I have to put more in.
What am I doing wrong here? I soak the wood and wrap it in foil before putting it on the charcoal.
Have you looked into a smoking tube like the ones from Amazen-n-Tube?
https://www.amazenproducts.com/product_p/amnts.htm
I got better smoke for a longer time with the 12" version.
Just tossing out some ideas.
When I was smoking with propane, the smoker tubes (with pellets) worked best - couldn't get long smokes with smoker boxes either.Thanks for the tip. That looks good. Or maybe one of those cast iron smoker boxes?
I'll have to ditch the wood chunks I have and get some pellets.
What do you use for a heat source? Charcoal?
