I was messing around with the ice maker on my refrigerator a couple of months ago. It stopped running and the are test points that you can measure voltage and even jump to force the timer motor to advance. I figured, why not just use the amps setting and use the probes as the jumper. I used the 10A and common connection on the meter. Well, I misread the damned letter and stuck the probe in the wrong hole. I went across 120V. Popped the fuse but also burned a couple of resistors up. I don't use the 10A function anyway and the rest still works fine. It did scare the piss out of me though!
