motorcityguy
Was cleaning up the inside of a recent receiver purchase, and noticed one of the wire wrap pins was somewhat loose to the touch. It was at the edge of the board.
I figured it was a bad/broken solder joint, but when I looked at the bottom of the circuit board, I found the solder joint was fine. Turns out the entire copper trace (complete with solder joint) was lifting off the edge of the board, allowing the wire wrap pin to rock.
I still have electrical contact, but don't want to leave the pin "loose". Can I just use a dab of super glue to hold the copper trace back to the board? I can't think of any other solutions.
