thorpej
Super Member
Diversions from day-job work desperately needed, so... been playing with the power supply for the 6550 amp I'm contemplating.
I'm concerned with using a choke in the power supply because of the inductance drop at full power. Even the 3H Hammond 193N is only rated at 500mA. I used this choke with much success in my 30W/ch ultra-linear 6L6GC amp, but my 6550 design has the output stage (total for both channels) idling at 300mA. So I decided to toy with the idea of a no-choke filter.
Nichicon makes some high-voltage, high-capacity electrolytics with reasonable ripple current rating that seem like a good candidate for this application. My favorite bridge rectifier has a ridiculous-A surge and 35A steady-state current rating, so I'm not particularly concerned about in-rush current.
Power transformer is a 400VA AnTek toroidal with a 360V secondary.
I decided to use a 1000uF @ 525VDC reservoir cap, followed by a 51R / 1000uF @ 525VDC filter. The filter is a low-pass filter at ~3Hz. Simulation shows in-rush is about 27A, which is well within the ratings of my chosen rectifier. I'm aiming t have 450V available at the plates of the 6550s, and expect a 3V drop on each half of the output transformer. The circuit as-drawn simulates at 455VDC at the OT center tap with a 42mV ripple.
I know @BinaryMike is an advocate of choke-less supplies (they don't ring when you hit demanding transients). Would love to hear others' feedback on this.
