I have a magnavox 8802 amp and was wanting to add a filament transformer so I could run 12v6 tubes (i have close to 30 nos ones) in it and change over the 6eu7 to 12ax7s. On the data sheets it says that a 12v6 uses .225 ma of current and the 12ax7 uses .3 ma of current in series .15 in parallel. That comes out to a maximum of 1.5 amps. I guess I'll be using a 120 primary 12 volt sec tranny. What would be a good size tranny to look for, can I just find a 1.5 amp one or do I need to get one that has power to spare. Will running the 6ca4 alone on the old heater curcuit cause any problems and is there anything else that I have not thought of that might give me problems.
Thanks Luke
Thanks Luke
