mistro
Well-Known Member
All I'm in the process of buying a modded Magnavox 9303 from another AKer on BT. It's my second tube system after my Conrad Johnson. The issue is the integrated amp to pair with this 15 wpc power amp.
Right now I have I have two integrated amps, the Luxman L-430 rated at 105 wpc and a questionable Technics SU-8080 rated at 72wpc, (Total harmonic distortion: 0.015% & 0.20% respectively) the question is are either of these two as integrated amps the correct sized amps to hook up to the Magnavox power tube amp rated at 15 wpc? I'm still committed to buying the Amp but if the two integrated amps I have are over powered to the Maggie then I'd like to understand what would be better now so I can plan my next acquisition. Thanks. Mike
