Maxxarcade
I'm working on a Magnavox AMP-175-55 to standalone conversion project.
When I tested it in all original condition, it sounds great with the exception of not having much bass. Comparing the schematic to other 6V6 push-pull amps, it looks like the coupling caps are quite small. Between the 12AX7 and the 6V6, there is 0.047uf caps, and between the input jack and the 12AX7 is 0.01uf.
On the Bogen DB110 for example, both sets of caps are 0.1uf. I've seen others go as high as 0.47uf between the 12AX7 and 6V6.
Is there any harm to be done by putting larger caps in the Magnavox? I also plan on replacing most or all of the resistors as well.
The other part of the project will be adding a preamp with bass and treble control. There may be enough room to add it to the same chassis, since there is quite a bit of unused space there, and even a spot for another tube socket.
Note that I have already removed unused components in the picture below. Also need to change the feedback network for channel 2 to match channel 1, and remove the balance pot. Afterward, I will install new power and speaker jacks, and a fuse holder.
Any advice is greatly appreciated
