Descartridge
Stereos been berry, berry good to me!
Looking for a technician to work on my Magnepan tonearm.
PLMK.
PLMK.
I probably asked back when you did it, what did you replace the connector that plugged into the arm with? I recall the Amperall part was no longer available.I've replaced the cable connector on one of mine, the end in the arm and the end on the phono cable but @Russellc has rewired one IIRC. I don't know that rewiring is much more work than replacing the connectors as the arm is disassembled to a point that shoving some wire through the tube and locking it in place is just a step or two more.
Would be good to know what kind of work you need done on the arm.
Let me make sure what you mean, you replaced the part that plugs into the bottom of the the tonearm? So you used a cardas on end of cable, and replaced matching plug in the bottom of arm with matching cardas? As I recall, the one in bottom of arm is not compatible with standard din plug, right? Or no?I used a Cardas connector and installed the mating end to the Magnepan tonearm cable. Since that cable had what appeared to be puppy teeth marks on the short suspension mobility jumper, I replaced that piece with a chuck of Mogami wire that is very similar. Needed to keep the suspension mobility to use the arm on a TD-125. Happy with the results.
A rewire to include the RCAs to the phono amp would be a step up, I'd guess but that means rewiring the arm and I didn't need to do that.
This thread: http://www.audiokarma.org/forums/in...onearm-almost-a-rebuild-detailed-long.753688/I guess we should hunt up that repair thread and link to it. It is the only instance of one being repaired that I recall seeing. Most consider the arm toast if the cable is dead.
Russellc
Don't know, never had one. I've had a Magnepan since early 81 and have mounted a few of them so getting further into them was not a problem. The gimbal on the 707 appears to need two-pin wrenches to open and I don't see how the DIN connector is captured in the arm base and it would need to come out. I don't think it would be too difficult if these issues were known.blue shadow....are you capable of rewiring a grace 707?
