This amp had Left channel outputs and pre-drivers blown due to speaker wires touching pos to neg. at the speaker. Right channel was working well and responded to trim pot adjustments correctly.
While amp board is out for repairs I decided to replace all electrolytics as well.
I got parts list from several threads and suggestions from other members.
Here is what I used:
C701 - C702 .47uF 50V .47uF 63V 505-MKS20.47/63/5 Wima Film
C703 - C704 47uF 50V 270uF 50V 661-EKZE500ETD271MJS
C707 - C710 47uF 50V 56uF 50V 667-EEU-FR1H560
C711 - C712 1uF 35V 10uF 35V 647-UPS1V100MDD
C717 - C718 22uF 35V 22uF 50V 667-EEU-FR1H220
C727 - C728 100pF 505-FKP2100/1000/5 WIMA FKP
H701 - H702, H705 - H706 KSC945CGBU
H703 - H704, H709 - H710 2N3440
H711 - H712 2N5416
H707 - H708 KSA733CGBU
R747 - R750 .24ohm 2W resistors
Cleaned trim pots with deoxit and turned amp on with DBT and attempted to adjust center voltage and bias as I usually do after rebuilds of such extent. There was no DBT flash so I assume there are no shorts. All 4 trim pots are maxed out and even connected directly to the power outlet center voltage is maxed at 31v (72v supply at J709 / J710) and bias across emitter resistors is barely 1.5mv. These readings are approximately identical on both channels. Amp plays through headphones with both channels. There is some distortion, of course, level is very low and obviously outputs are not even in the equation due to such low bias.
I've rechecked all transistor datasheet layout against markings on the board and can't see what I could've missed or miss-installed to cause this situation. Mis-print on the board?
Anyone run into this situation?
Any advice would be greatly appreciated.
H711 - H712 2N5416
