Chris Lauver
New Member
Hey guys, I am having an issue with my Marantz 2325 while listening to vinyl. This unit has had the power supply, tone board and Phono board rebuilt, all switches and pots cleaned, and all voltages set to service manual specs. The issue is only when the amp is in phono mode. I will play an album and it sounds great, then out of nowhere it will make a pop or crack sound like the record has a scratch in it, but the record is fine. It will play fine for a while, then again out of nowhere a pop/crack sound. It may do this only two or three times during a whole album. Also, when I go to power off after playing for a while, there is a pop in both speakers. It does not pop when turned on and it only pops on shut off after it has been playing a record for a while. It has none of these issues in any other mode, only phono. Also need to mention, I have tried two different turntables and same problem. Thanks, any help is much appreciated.
