I've had this Marantz SD630 sitting around as a project and I just got the belts online. It takes two belts, a flat and a square. I replaced the square easily, but I'm not exactly Shure where the flat belt goes. It appears to have two equal-sized flywheel (?) close to each other, and the motor is a good inch or so next to one of them. My question is, how does this flat belt go in? There's some posts here and there, but they don't rotate or move in any way. I want this deck to work, so I can compare Dolby B, C, and dbx. Thanks!
P.s.- The deck has a rotating head, if that changes anything.
