catrafter
Marantz Specialist
I've been meaning to post this for quite a while so when I needed these stands today I took a few pictures.
You will need:
4 ea countersink head 5mm screws about 35mm long
4 ea 5mm nuts to match the screws
4 'fender' washers, 2 inch diameter with a 1/4 inch hole (if I did it again I would use 1 3/4 inch diameter with a 1/4 inch hole)
Put each washer on a screw, add a nut and tighten it down. Now, whenever it would be advantageous to stand the unit on it's face for better access, screw these into the face plate bolt standoffs that are mounted on the front chassis.
Tom
You will need:
Tom
