Hoping someone can help guide me in the right direction. My 19 has distortion in the right channel. I have localized it to the driver board. With a clean sine wave in this is what I get out (see pic). All incoming supply voltages to that board measure correctly per the schematic so I suspect a component failure. I have placed an order for Q1201, 02, 03 because some say these are prone to failure or become mismatched beta wise, however they do test good using the diode function on my meter.
For those of you that may be having intermittent tuner issues here is something I found that was the problem on my unit. There is an inductor/choke connected to a tag strip that was causing the problem. One end of the tiny wiring the makes up the coil was not connected properly to the lead of the device itself. My scope confirmed this and so a quick hit with the soldering iron and we are now back in business. I also hit the other end for good measure. See pic for culprit.
