Marantz Pmd 430 cassette deck ac power supply
Discussion in 'Tape' started by reeltoreel68, Nov 4, 2011.
  1. reeltoreel68
    reeltoreel68 Member
    81
    niskauna Ny USA
    I have the possibility of purchacing a Marantz pmd 430 stereo deck. the sell says it works well on batteries but has no Ac power supply. can it use a universal Adaptor or is it a special voltage?
  2. petehall347
    21,683
    uk.. the middle bit
    it will have to be correct voltage and amps ..more amps is ok less isn't . voltage within 1 volt is maybe ok ..hope that makes sense
  3. soviet123
    soviet123 Active Member
    383
    Quebec City
    Someone online says 4.5 volts for this deck.
  4. skibjr
    skibjr AK Subscriber Subscriber
    1,532
    West Plains, MO
    Marantz DA-36 is the original adapter - 4.5VDC, 700mA. There are two of them on eBay right now for $9.99...
  5. bobschneider
    bobschneider AK Subscriber Subscriber
    1,278
    Back in Chicago
  6. sssmokin99
    sssmokin99 Well-Known Member
    934
    Kansas City
    I have one of these- IMO, it is worth getting the correct power supply. There wont be any more three head, dbx, portable cassette recorders coming on the market ever again.....:D
  7. jlb2
    jlb2 Well-Known Member
    783
    Hi, I had a 230 for years, that I used to power using a regulated universal adapter, with the correct voltage setting and plug. It worked like a charm. I don't think the original adapter would add anything more than being genuine, it was an ordinary design.
    If I remember correctly, the best voltage setting was 6V, not 4.5V, Which makes sense since there was a 4.8V accessory battery that was supposed to be charged internally from the power input. 4.5V was not enough to fully charge it.
  8. sssmokin99
    934
    Kansas City
    Interesting point. I never had the rechargables, so would have never known. My point was simply that he could get a "genuine" PS for a reasonable price, still. It is a great deck....
  9. bobschneider
    1,278
    Back in Chicago
    I just measured my original AC adaptor, and it's putting out 6.6 volts.
  10. chan tran
    chan tran Member
    84
    I believe the original adapter isn't of the regulated type and thus measuring the voltage without the load would read high. With a well regulated power supply I would want to set it for about 5V.
  11. jlb2
    783
    chan tran you are correct, the original PS is unregulated. 6.6V is the voltage with no load connected, while the quoted 4.5V is when fully loaded (which is never supposed to happen in normal use, there is always a safety margin, sometimes substantial). In actual use, the voltage can be anywhere between 4.5 and 6.6V. The usual power blocks don't have a 5V setting, but the proper voltage is not difficult to find really: there is a battery voltage check button on the recorder, you set the voltage for the needle to be in the right zone of the meter. I have just had the opportunity to check a CP230 with a regulated power block, here are the results. With 4.5V you are just in the bottom of the safe zone: the deck works ok, but FF and rewind are fairly slow. With 6V you are in the upper part of it, everything works fine. With 7.5V the needle exceeds the top of the scale, so I don't consider it safe. I'd go for 6V.
