Mark Audio Alpair 12P Pensil Build
Discussion in 'DIY' started by StevenZ, Jul 14, 2012.
  1. StevenZ
    StevenZ Texas or nothin'
    1,921
    San Antonio, TX
    Hey guys,
    Just thought I should start a quick little build log here for my newest speakers. As some of you know, I've picked up a pair of Mark Audio Alpair 12P full range drivers. These are Mark Fenlon's newest top of the line (as well as largest)drivers which use a Japanese paper cone, as well as Japanese suspension parts, non-resonant plastic frame, reversed roll rubber surround, etc. They are made in small batches and are hand assembled in China with Mark Fenlon carefully watching over quality control to make sure that each pair comes out perfect.
    On to the build.
    I drew up the cabinet in AutoCAD and ported it over to our CNC router. Here is a quick video of the CNC router cutting the parts out. *Volume warning, it may be loud*.
    http://www.youtube.com/watch?v=KXe8WVix4zA&feature=plcp
    This original enclosures were supposed to be out of Domestic hardwood core plywood but it seemed my machine wasn't calibrated properly as well as the material being under 3/4" so I threw away the entire sheet and started over. This time around I got some true 3/4" MDF and triple checked the machine parameters to make sure everything would be perfect before wasting another sheet. The parts came out absolutely perfect, accurate to .0001".
    Moving forward, I had a little time this morning to throw the enclosures together. Here are a few photos of the build. As you can see I opted for window bracing instead of the original "holey" bracing called for in the plans. As of right now they are waiting in the finish room and have a couple coats of sealer already thrown on. Monday they will get an off-white paint sprayed onto them and should be fully mounted by Wednesday. I rounded over the front edges to give it a "softer" look and reduce diffraction.
    Also, as you guys can see I added more material to the inside of the cutout due to the flush mounting rebate being so deep, only leaving 1/4" material to screw into. I added 1/2" more which gives 3/4" material to screw to. I did a small round-over on the inside edge of the cut-out but I don't think it's adequate as I believe that the driver will need more room to breathe. Soo.. with the enclosures already sealed up I'll just take a small sanding wheel from a dremel and chamfer the inside edge a bit. Shouldn't be a problem, just a little time consuming.
    Anyways, I'm excited that I've made progress on the enclosures and can't wait to listen to them next week. Hope you guys enjoy!
    Cheers,
    Steven
  2. StevenZ
    1,921
    San Antonio, TX
    Here are a few photos of the drivers. The drivers are sold in pairs with matched parameters. This set is matched at 44hz.
  3. Vaughn
    Vaughn AK Subscriber Subscriber
    2,311
    Bellingham, WA
    I got one more hz than you:nerd:
  4. ejfud
    ejfud Audio Pinhead
    5,354
    St Paul, MN
    Great build pictures.
    Patiently awaiting your thoughts on this build.
  5. Vaughn
    2,311
    Bellingham, WA
    +1
    I'm trying to decide which direction I'm going to go in for these drivers. Seems like there might be several available soon.
  6. StevenZ
    1,921
    San Antonio, TX
    Thanks guys! I talked to a few people who have already compared the Ken style enclosure and the Pensil and the general consensus is that the Pensil, even standard sized, walks all over the Ken style box. I would have gone with the Super Pensils to gain a bit more bass but the dimensions were killing me. The "Standard" Pensil is more aesthetically pleasing and should be able to blend in well with the room by opening up more placement options.
    -Steven
  7. Redboy
    Redboy a few good watts Subscriber
    11,199
    Twin Cities, MN
    Don't pay me any mind... I'm just here for the show.
    :thmbsp:
  8. ejfud
    ejfud Audio Pinhead
    5,354
    St Paul, MN
    So what are we talking about as far as bass in the two Pensil designs?
  9. StevenZ
    1,921
    San Antonio, TX
    Honestly I have no idea. The designers of the Pensil cabinets (Scottmoose & Planet10) absolutely refuse to publish any measured response graphs or even give a general estimated frequency response. As to why they don't is anyones guess. Also, I seem to get in trouble with Planet10 every time I don't use his signature 'holey' bracing for his enclosures and am awaiting a solid response from him as to why he thinks my window bracing will hurt the performance of my build. I'll post his response here if/when he replies.
    Steven
  10. StevenZ
    1,921
    San Antonio, TX
    So, Dave says that with my bracing it may disrupt the 1/4 wave TL and adversely affect the bass response, though another fella answered (Bob Brines) and included that he's done the same bracing in many TLs of his own and has had zero adverse affects and no measurable differences in sound. Bob did recommend more bracing, though, but to be honest my bracing is primarily to allow the polyfil to stay in the enclosure without falling and coming thru the port.
    If I hear excessive panel resonance I'll add some decoratively cut hardwood panels to the outside to stiffen up the enclosure a bit, though, the reason I used MDF is because of it's natural panel damping properties. In my personal opinion, and experience with many building materials, I favor the acoustic properties and damping of MDF over birch plywood. Though this thread isn't the place to get into such a topic, it's merely a personal preference. I'll keep you guys posted and update the thread with any findings as I move along.
    Thanks,
    Steven
  11. ejfud
    ejfud Audio Pinhead
    5,354
    St Paul, MN
    I built my Jordan two ways with window bracing. Bob's design is built this way and they sound great.
  12. Rick Vestal
    Rick Vestal Have a nice day and duck!
    1,898
    Colorado Springs, CO
    That was my first time seeing wood cut with cnc... Are there companies out there that you can provide drawings on paper to them and they provide you with a finished cut set? Being a condo dweller I don't have access to large saws...
  13. StevenZ
    1,921
    San Antonio, TX
    Absolutely. Most larger custom cabinet shops should be able to help you out. I can't be sure on how much they will charge, though. It only took me about 10 minutes to draw the program, and another 4 to cut the material. So all in all, 15 minutes from design to finished product.
    -Steven
  14. scott1019
    scott1019 Super Member
    4,938
    Pinckney, MI 48169
    Looking awesome Steven! Keep up the good work! "The eyes of the Ranger are upon you"
  15. StevenZ
    1,921
    San Antonio, TX
    Copied from my other thread "I Love Full Range!"
    Well fellas, it's been a while but I finally had some time to get the cabinets sprayed and drivers mounted. Unfortunately my local supply store for polyfill was closed today so the cabinets have zero stuffing in them but my results are pretty damn good so far.
    So far, even though I'm in my 1st hour of listening, they're amazing. I have always loved the sound of Mark Audio drivers, and these are no exception. Simply beautiful sound. Well balanced and as good as you can ever want from a full range single driver.
    I'm using the "standard" sized pensil cabinet and am hearing some very good low end extension and I'm sure the "super" Pencil enclosure will produce a bit more. For my listening habits and small listening room I feel the standard pencil is perfect. It's aesthetically pleasing and easy to properly place in a small room due to it's small foot print.
    All in all i can't wait until they're fully broken in. The manufacturer suggests 100 of soft listening with natural instruments and then gradually increasing the volume. It's sure going to be a long process as I'm already feeling the urge to crank it (and have done so a few times ).
    Cheers,
    Steven
  16. scott1019
    4,938
    Pinckney, MI 48169
    Amazing work as always!
  17. 240sx4u
    240sx4u Lunatic Member
    11,317
    Madison, WI
    I really like the white color, they look great!
  18. djnagle
    djnagle Lunatic Member
    11,646
    Albuquerque, New Mexico
    Very nice. I've not heard those drivers, but I've heard a lot about them.
  19. StevenZ
    1,921
    San Antonio, TX
    Thanks for the compliments, guys!
  20. StevenZ
    1,921
    San Antonio, TX
    Fellas, just a quick update. I have about 50 hours (of the 100 break-in hrs) on them so far of light listening and this morning I decided to get a little wild and turn it up a bit more than I usually do. What I found was mind blowing. Granted I didn't get real crazy, but man was I surprised. Beautiful sound, lush bass, micro-details galore. These drivers are such a fresh breath of air for me. I really can't get over how good they sound and how pleased I am that they have usable bass output in such a modest enclosure.
    Generally speaking you'd need a large and complex enclosure to extract any low frequency output from a full range driver but this is not true with Mark Audio. With gobs of suspension travel and a relatively easy enclosure build you can get a well rounded speaker that should impress even the most demanding audiophiles.
    Another 50 more hours of low-level break-in and I'll be all smiles again. I can't wait until these are broken in a little more so I can have my buddies come over and do some critical listening with me. A+ Mark Fenlon, A+.
    Also, I should mention that even being a bit "wild" with the volume this morning I still never noticed cone movement. If it was moving it was less than 1mm. Even at this small of movement I was getting enough bass to feel that a subwoofer would never be needed. So, I'm assuming if I were to ever push it hard enough to use it's suspension travel I'd be getting more bass than i could possibly stand in such a small room.
    Cheers,
    Steven
