I have been trying to match output transistors for Vbe as I use 9 pairs in the OPS stage. It is much harder than it sounds as tempco of Vbe is -2mV/deg C. You handle it, it start changing. You breath on it, it starts changing. People suggested immerse in water to do it, it's way too messy. So this is a way I come up with as see what you guys think.
See attached immage, I use the proto plug in type board, I just ordered 60 of the 51ohm 1% 2W 100ppm/deg C resistor. I am planning to put in all 60 of the power transistors in like the circuit shown. I am drawing 100mA through each transistor like in my amp. I am going to let it sit for say 1 hour to let the temperature settle at higher temperature. I then measure the voltage different between the emitter pin of two different transistors and look for the difference. I just keep going and note down the difference in voltage between two emitters.
Notice I stress to measure on the leg of the transistor as I don't trust the interface between the leg and the plug in prototype board, there might be a drop across the contact and it's not the same for every transistors. I think I can trust the base contact of the prototype board as the base current is only 1mA, it's not going to have much voltage drop across the contact even thought it's not a very good contact.
The good point is all the transistor are in the exact environment, so even the room temp change a degree or two during measuring, all transistors subject to the change at the same time and it will null out the difference.
This might sound tedious, but if you think of the alternative, dumping in water and measure one by one?!!, you have to use a thermometer to measure the temperature of the water, stabilize the temperature every time, then the drying and cleaning. The water is going to heat up gradually when you keep doing it, all it takes is 1deg change and you ruin your measurement.
Let me know what you think. I just ordered 60 resistors and a 5V 10A supply( $13 only free shipping, very cheap).
Notice I put 0.1u ceramic cap in the circuit, I think the transistor might oscillate without them. I have been doing matching, so far I have no luck at all.
