May I lubricate center shaft, gear of Pioneer PL-15D
Discussion in 'Turntables' started by liemjerry, Dec 2, 2018.
  1. liemjerry
    liemjerry Active Member
    438
    Indonesia
    Hi friends
    I am cleaning my Pioneer PL-15D, and after I put off the platter, I see section like center shaft, gear that when turntable operates, it move together, like this picture :
    may I lubricate that section that indicate with 2 arrows above? or keep it dry/can't lubricate that?
    Please suggest
    Thank you
  2. Beobloke
    Beobloke Super Member
    1,803
    South UK
    That's the main bearing so, yes, it should be lubricated.
  3. liemjerry
    438
    Indonesia
    ok, I will lubricate those section, thank you
    is it will affect to stability, quietness of platter when it is spinning?
  4. TomInTacoma
    TomInTacoma d/b/a Vinyl Reclamation Sponsor
    851
    DuPont, WA
    If you don't lubricate it, it it will become more and more stiff and eventually the belt will start slipping.
  5. charles 1973
    charles 1973 Super Member
    3,094
    I put some sewing machine oil there on my Rondo 2000, which is similar to the PL15. It didn't stop the grinding feeling though. I guess there is a bottom bearing that should be cleaned and repacked, or replaced.
  6. TomInTacoma
    851
    DuPont, WA
    To do it properly, you'll need to remove the spindle assembly, disassemble it, clean it out completely and then lubricate using the correct lubricant. This isn't something you can squirt oil on and call it "Done".
    timind, Beobloke and danj like this.
  7. Schoute
    Schoute New Member
    6
    It's always good to lubricate your shaft :jump:
  8. Electone
    Electone Well-Known Member
    776
    London, Ontario, Canada
    There will be a retaining nut on top of, or underneath the plinth. There may also be a retaining screw that keeps the spindle from being pulled out of the bearing. Some have a ball bearing as well. Clean the spindle and bearing with alcohol and the re-apply a good quality oil to both.
  9. liemjerry
    438
    Indonesia
    thank you for suggestion I'll try step by step cleaning
