Hi all,
I refoamed my first pair of speakers.. I'd have preferred a cheap set to practice but I got a pair of Ohm C2s on a budget and this was my trial by fire. Used a SimplySpeakers kit with their adhesive and directions.
I used less adhesive than recommended on the first woofer and also mis-centered it relative to the cone by maybe 0.5mm-- however, I used their hand-centering recommendations and also played a 30hz tone to help center everything before I glued it to the outer basket. Everything appeared good with test tones and music--there is no obvious buzzing or rubbing.
The second woofer was done with more adhesive and I was more careful to center it at first. Same technique with a louder 30Hz tone, as I was confident this worked and would make nasty noises if I did it wrong. No nasty noises happened and I believed both had gone well.
End result-- both speakers sound beautiful but the second has obviously more bass than the first. Alone, I'd say the first needs tweeters set -3db to match 0db setting of the other. But together, the high-frequency volume seems the same while the woofer is what's lower in the first speaker I worked on.
There is no obvious "rubbing" or buzzing. Any idea what could have gone wrong that could be blamed on my refoam?
I was pretty careful to get the speakers back in with red wire to positive and black to negative. This sounds like a phase issue but it probably wasn't in this case
