gkwolfman
USAF 1973-1980
This is revised to state.....That I am stupid........the snipping of zip ties was NOT NECESSARY....
If you have the right type of flat head? screw drivers, you can access your ADjustments from the bottom side of board.
Plus, you have better access to any measuring points...........maybe not stupid, but, careless for jumping in at it without knowing. Maybe the same thing?
I am going to attempt to adjust my DC and Bias.
My DC is 31.0 on one side, and about 11.0 on the other side.
Just got the amp opened to attempt the adjust and find the Bias points and
measurements.
Anyone have.... what the values are for the Bias and where to + and - for the checks.?
I should be able to figure out the DC, very carefully. That one is a "No Brainer", I would assume. I use the blue cap Variable Resistors (VR202=Right and VR102=left) for the DC off set. I hope that it was the right ones. It did adjust the DC values for both sides of the speakers.
I am puzzled on the Bias part. I always had just two VR's for bias, this looks like there are two on each side, VR101 VR103, and VR201 VR203.
Plus, I need to find out where to put meter ends + and - , to read the bias.
any help would be great.
Sorry about the photos, thought they would be larger, but , you can still click on them.
measurements.
