Hi all, I have a Fisher F-591 console system (69T chassis) that I've been using daily for about a year. Appears to be stock (even the electrolytics). A few days ago, I noticed the audio (at least on FM mode) was noticeably distorted. I also noticed that the stereo indicator wasn't lit (and it definitely wasn't receiving stereo sound).
Since the 'lytics were original, they were my first suspect. Sure enough, there was excessive AC ripple on a few of the DC rails. New caps took care of that problem. Audio sounds fine now.
However, I still don't have FM stereo (mono is fine). Checked the basics; incoming signal strength is adequate, station is broadcasting in stereo, mono switch is not engaged, stereo indicator lamp is good. If I generate an RF test signal with a strong enough 19KHz stereo pilot, I can get the stereo multiplex decoder to become active. Additionally, if I add in my own 19KHz audio signal to a strong broadcast signal, I can get the stereo decoder to activate. Its just that broadcast signals on their own aren't strong enough.
I checked the alignment and it is good. (Why would alignment suddenly change, anyway? Stereo worked fine a few days ago). I also adjusted the AGC trigger control with no improvement.
I traced the 19KHz signal through the decoder circuitry right up to (what I assume to be) the frequency doubler (Z403 on the schematic). I'm not getting anything out of Z403. However, the 19KHz signal at the collector of Q402 (input of Z403) is only about 175mV. Considering the forward voltage drop of the diodes in Z403, I don't think the 175mV signal is sufficiently strong. This is all when tuned to a broadcast station. Again, I can generate a signal that's strong enough, but for some reason, typical broadcast signal stereo pilots just aren't quite strong enough by the time they get to Z403.
For testing, I also tried amplifying the baseband audio signal (from the ratio detector) going into the decoder. Using an external amplifier, I can amplify it enough to get the decoder to activate, but then the audio is noticeably distorted.
Where in the circuit might the higher audio frequencies be rolled off? It seems like the 19KHz pilot (and presumably higher frequencies) are being rolled off or attenuated somewhere in the circuit, presumably before the stereo decoder. The schematic says the 19KHz signal at the input of the decoder should be 30mV. If I generate a signal of that amplitude, the decoder works, so it seems like the issue is in the IF amplifier (which includes the radio detector).
I'd appreciate any suggestions or insight! Sorry for the long post but I wanted to be thorough in my description.
