When I bought my Citation 22 frome Ebay it arrived with some damage to the mounting bracket for the speaker terminal PCB. One side of the PCB was unsecured but it didn't affect the operation of the amp so I wasn't worried about it. While I was changing the speaker wire the other day, one of the terminals broke off of the circuit board. I decided it was a good time to switch over to 5 way binding posts. I ordered the Dayton posts from Parts Express and got started.
First I de-soldered the wires from the board and removed it from the amp. Then I cut a 2 1/2x2 1/2 inch piece of 1/8 inch aluminum plate, then more or less centered it where the PCB was inside the amp and marked all the holes. Then I drilled all the holes and test fit everything.(the posts have small tabs on one of the plastic washers that will need to be removed)
I then mounted the plate to the amp (with the posts removed) and soldered the wires to the negative posts, then mounted them to the plate. Then I mounted the positive posts to the plate and put the small wires from the 3 wire connector at the bottom of the PCB through the holes on the posts. The gray wire goes to the right and the black wire goes to the left positive posts and the center wire is unused. Then I soldered the wires to the posts. I'm happy to say it worked like a champ, and the posts are much easier to deal with and you can use bananas if you wish to.
Hopefully this will help someone
