I have just implemented bridged mode on my NAD 3150 and 2150 to drive my Magneplanar speakers. However, after the system is on for several minutes, a low-frequency pulsing sound starts up in the left speaker (driven by the 2150), pulsing at about 150 bpm, though it speeds up and slows down a bit unpredictably. It is not dependent on there being a signal from the 3150 preamp, and switching L/R at the input side doesn't change things; it's still just the speaker driven by the 2150 power amp. I would like to solve this problem!
Here's the back story.
I had been running the preamp outs of my 3150 to the 2150 power amp for over 10 years, in the belief that I had a bad left power amp channel in the NAD 3150. I had originally bought the 2150 to permit operating both amps in bridged mode with these Maggies, but then this problem developed where I was getting no output on the left channel, so I just left it as-is all this time.
Today I was preparing to finally take it to a local electronics shop to have it fixed, but I wanted to give it one more quick going-over to make sure it wasn't something bloody obvious. And as fate would have it, it was. The damned connection from the left main-in RCA jack to the sort of blade connector on the backside that connects it to the circuit board was apparently not making good contact due to years of corrosion/tarnish. A few shots of DeoxIT and jiggling and pushing and pulling the connector (I couldn't remove it completely), and all was fixed! Also fixed the scratchy volume and balance pots and everything was getting better.
I carefully followed the directions on bridging setup in the NAD manual, and the system does work, and there is definitely a power increase to the speakers, but this pulsing problem has also started. I just don't know whether I should go back to the way it was or... or what. I want to use it this way, I've been wanting to do this for ages!
One thing I'll add is that the 2150 is getting its AC power via the 3150 convenience outlet. I first had it plugged into the switched outlet, but then tried the unswitched to see if that made a difference. It didn't. However, when it was in unswitched, I once turned off the 3150 via the power button, and the pulsing sound got considerably louder.
If anyone has similar experience or can offer any diagnostic pathway for me, I'm all ears and eyes. Please let me know!
