SanJoseMichael
Sorry to be such a noob, especially at my undisclosed age. Came across an AK posting (Amplifier Distortion, DC-Offset, and You!) which led me to dig out the Fluke meter and go wandering inside an old Denon and a pair of NADs I've been running lately. What follows is from the service manual for the NAD 3225PE/3020I. I understand the Center Voltage part, but not the Idling Current part. See photos as well.
IMPORTANT
Speaker impedance switch should be in 8 ohm position while adjust center voltage and idling current.INITIAL ADJUSTMENT (No load connected)
A. CENTER VOLTAGE
1. Connector DC millivoltmeter to L channel output terminal.
2. Turn on and adjust to 0 V +/-30mV with R411 (470 ohm). Connect DC millivoltmeter
to R channel output terminal and adjust R412 to 0 V +/-30mV.
B. IDLING CURRENT
1. Remove solder short across R455 and R456.
2. Connect DC millivoltmeter across R455 (1 ohm) (output transistor's collector resistor) and
adjust R443 for 26-30mV reading on meter. Repeat adjustment with R444, connecting meter
across R456 (1 ohm).
3. Leave power on for minimum 5 minutes.
FINAL ADJUSTMENT
C. CENTER VOLTAGE
1. Repeat step A about.
D. IDLING CURRENT
1. Repeat step B and adjust with R443, R444 for 30mV reading on meter.
2. After the alignment is finished, 1 ohm resistor R455, R456 is shorted by solder short.
My brain seizes up at B. IDLING CURRENT:
I see that R455 is a 1 ohm resistor, with perhaps a (missing) solder short between P402 and P403 (assuming P402 and P403 are in parallel with R455)?
Likewise R456 is a 1 ohm resistor, with perhaps a (missing) solder short between P405 and P406 (assuming P405 and P406 are in parallel with R456)?
Here, I assume I set my meter to measure millivolts, with probes on both ends of the resistor (in parallel with the resistor), adjusting with R443 and R444 respectively. Is that correct?
And, I note the solder short, however it may have been implemented, has not been replaced. What effect might that have on current performance?
Can I just tack solder a jumper over R455 and R456 on top of the board, or try to make small wire U-shapes to plug between R402 and P403, also P405 and P406?
Appreciate any guidance that can be given.
IMPORTANT
A. CENTER VOLTAGE
B. IDLING CURRENT
FINAL ADJUSTMENT
C. CENTER VOLTAGE
D. IDLING CURRENT
